Took a good look at the water pump tonight and the weep holes were clear, so guessing that wasn't it ????
Hey I'm looking at a 01 lb7. He said the water pump was leaking so he replaced it. He said it's mixing coolant into the oil. He said he thinks he messed up the seal / gasket. Would this cause coolant in oil? He said the coolant system is not pressurized.the truck is studded.It was a hard lesson learned. I would pressure the coolant system and never lost pressure. But was loosing a lot of coolant in the oil. So I pulled the heads to have them checked. While I had the truck tore down that far I decided to change the 200k water pump. And that's when I found the problem. I couldnt tell the holes were plugged until the pump was off. And I never expected the pump because it wasn't leaking.
