Converter Unlock Switch
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Has any one figured out how to do a unlock switch yet for sled pulling. I know brayden has the ally locker but i dont need anything that fancy or expensive. All I need is to be able to unlock the converter at the end of the track without losing reverse.
I understand that the converter has to be applied with PWM but it shouldnt need to be unlocked right? I have zero issues with lockup but need the converter unlocked to hold 4th gear and since the ally will never manually downshift to 3rd when its supposed to I dont have another option.
Anyone got any ideas?
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
I have one on my truck but I didn't install it as it came this way. I'll find out how it works without losing reverse as I thought I was told it won't as long as the co-pilot is on but will make sure.
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
I don't know the answer. I am moving my turbobrake over out of my 05 to the puller so I can put a switch on it.
To answer your other post about the S400, yes I plan on an unlock switch.:hug:
9,905
151
LOL most guys are having trouble getting the converters to lock!!
I would think interrupting the PWM signal would cause it to unlock but I'm sure you would get some codes and maybe some other weird side effects. Mike L. or Brayden may know.
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Don't laugh, I made a sketch using paint. I think this would work using a DPDT switch
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
You can run a ground wire and it works but when you flip it you will loose reverse and will have to clear the code before you can unhook from the sled.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
I have one on corries truck, Just find the TQ clutch control wire and use the switch to break it, switch in closed pos will operate normally, switch open unlockes/or keeps from locking the converter. I can find the wire for ya but not til tomarrow!!
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Is it the brown wire #418 pin 29
dmaxlover
Mar 17, 2007
453
WI
It would be nice to have a 3 way switch. Position 1 would be converter lock, 2 would be stock, and 3 would be unlock.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Yep thats it, I cut it just out of the tcm, run it to the dash to a on/off switch, and back to the wire. It works good, it will unlock it I always make sure the truck is in a non comanded lock situation befor i switch the circuit closed after unlocking to avoid a non PW lock!
This is in no way intended to be considered a lock up switch!
dmaxlover
Mar 17, 2007
453
WI
Ben, I see you lurking... Your good at this kind of stuff, now that your a vendor, how about you build us a simple lock/unlock switch thingy, without all the limping issues.
