Converter bolts
maine04max
Dec 11, 2008
1,009
Are converter bolts reusable? I have a tranny coming soon . It has a ML precision converter LBZrks thinks the bolts will be coming with it . If for whatever reason I cant reuse or they arnt there , what do I need to use for bolts ?
Thanks Craig
racinmike77
Sep 14, 2008
1,029
MD
you need to make sure they are the right length for the converter and use locktite. Personally id order new ones to be safe.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
uh oh...I used my stock converter bolts with my ATS 5 junk(star)
I wondered what that rattle was :confused:
jpowel29
780
Bentonville, Arkansas
If you are running an aftermarket flexplate the thread depth will be longer than stock. ATS uses a different metric thread (10mm x 1.25 I think) and the other converters that I have used are 10mm x 1.50.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Reusing them will be fine. Just make sure they are the correct length. I would never use stock TC bolts in an aftermarket TC. Bolts can be cycled millions of times, they are fine.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Reeces trans has used the same ones twice, another buddy ha used them twice and one of our friends we pulled his trans like 3 times and a shop pulled it once before. Years later they are all still fine. You guys reuse bolts in motors do you not?
13,712
773
I've also reused my converter bolts 3 times without any problems. I'll probably replace them this time though.
Not bolts that are under a lot of load. Main bolts, head bolts, flywheel bolts, crank bolt, cam bolt all should be replaced.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
I've also reused my converter bolts 3 times without any problems. I'll probably replace them this time though. Not bolts that are under a lot of load. Main bolts, head bolts, flywheel bolts, crank bolt, cam bolt all should be replaced.
I understand all this I was just saying because people think it's a huge deal and most of us have reused them. The only time one ha snapped was a brand new one
racinmike77
Sep 14, 2008
1,029
MD
Its cheap to buy new ones but on the other hand as long as yo have the correct bolts for the flexplate and converter with some loctite you will be ok
