Convert 5th Wheel to Gooseneck
kmac
Mar 27, 2014
Iowa
best of both worlds
i just traded up to a 2012 2500hd silverado from a gasser the 12 came with a B&W turnover and my in my old truck i had a superglide fifth wheel which i kept but not wanting to give up the B&W with a little fabricating i installed the superglide on the frame first then was able to bolt the B&W mounts on the outside of the glide mounts they use the same bolt holes the superglide comes completly out of the bed also leaving it flat other than a couple of holes in the bed it works great throw in a bed mat if needed. Best of both worlds
jevanb
Feb 28, 2011
159
montrose, michigan
But a slider hitch on a newer one is a big no no. My old camper required me to have a slider. My new one will take out my tail gait if it slid back. So I sold my slider cause I did not want the risk of it. I don't think they make a sliding ball.
how is that possible?? I have a SB with a superglide slider, and a 2012 5er, as fact I see lots of new trucks and brand new trailers with sliders and they are ok. You might have a extended pin box that you did not know about..
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Pulling my brothers camper is the same way.
jevanb
Feb 28, 2011
159
montrose, michigan
extended pin box and sliders do not go together.. no reason for a normal pin box to ever hit the tailgate when slid back, their is less room when the trailer is on a 90 in the bed but the longer pin box can also cause fitment issues here.
Was you bed clearance above 5 inches?? the lower the pin box the less room you also have
