Considering a Lenco/Bruno
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Simon, what's your target raceweight?
Guessing around 5400lb. Everytime I remove something I have to add weight with safety equipment ...... Not that I need to tell you about that.
The trans with Bruno bellhousing and converter should be around 200lb
I want to get some exact numbers on it before install though
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
It will be interesting to see how it does. If it holds up to the weight and torque, it might be the new wave for racing pickups.
A typical monster truck weighs 9000lb and a lot of them use the cs1 Lenco
But I have no personal experience with it.... So time will tell.
If it does or doesn't work you guys will hear about it:D
http://www.markwilliams.com/driveshaftSolid.aspx?CategoryID=207
http://www.ctmracing.com/storefront/storefront.php?function=viewproduct&productid=6&categoryid=2
custom8726
2,784
Upstate N.Y
If it does or doesn't work you guys will here about it:D
The way they (Monster trucks) throw those things in and out in 15minutes with 1 guy is pretty dam impressive... Although its kinda apples to oranges in comparison to our trucks it will be interesting to read what the total set up weighs and also if its any easier to pull in and out then the Allison or Duraflight for maintenance..
Diesel power
Jun 2, 2008
855
maryland
Bruno 85+
lenco 105
Convertor 50+
fluid 20+
260 ish. ;)
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
Shouldnt even need to use a trans jack.:D
Diesel power
Jun 2, 2008
855
maryland
Lenco has the weight on there site, doesn't that include the Lenco drive though?
The lenco drive is way diferent and much lighter than the bruno...
I have close to the same set up set up in my truck now, i know exaclty what it weighs, yours however will be heavyer, due to the bigger shaft and lock up VB installed and the bigger bell, and convertor.
you will be at least 260lbs everything together.
BTW whats that in your avatar? cougar....
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Thanks for the info..... Can't wait to get home!
Some ass clown thought the girl in my avatar was ugly...... So I put a picture of something more his style.
Dallas S
486
33
Alberta
im gonna have to make the drive out west and see how you boys race... People here are still stacking boxes on there dmax's..:roflmao:
Very interesting project! cant wait to see the results :thumb:
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Sweet, i knew i was close, you running a CS2? 3 speed or 2 speed?
CS1 3 speed Tcase 1:32 overdrive
Have to look back at the notes but IIRC 2:11 first gear
I have no idea on the weight of the Alli? But its nice being able to grab a trans off the bench and put it on the trans jack:D
