compression test results
S Phinney
4,008
Quncy, Fl
Yep lbz rods i didnt make to much hp imo but i did hit 1373 tq which may have been the rods undoing. It may be a cup still or headgasket but im just not seeing as much pressure in the cooling system as i should for losing 50-70psi :confused:
Also would you guys reuse a crank that's got 245k? It was balanced 4xk miles ago just debating on if i need some other parts
With the blown gaskets that I have changed out there was zero pressure in the coolant. There outside coating had deteriorated and caused the leaking until heat got into the engine and helped it seal off.
S Phinney
4,008
Quncy, Fl
Probably would help rule that out. When cold it would show compression down about 80-100 lbs.
