Compound turbo setups
lunati397
Sep 21, 2011
33
Just a question on compound setups does it only use one waste gate on the second turbo or are they both wastegated
lunati397
Sep 21, 2011
33
could you explain why and when because you would think that one would overspool or the second one would basically be a blow through at one point and it would have to be gated on the first one
eric.davis
Nov 12, 2011
5
It really all depends on how your turbos are set up and how quick you want them to light. The HP will be driving your LP obviously and the tighter the exhaust housing on your HP is the quicker you'll be able to spool but then with that quicker spool you'll also have higher drive pressures so you'll want to gate it and dump into your transfer that spools your LP turbo.
It comes down to turbo selection and if you want a tight or loose housing based on what your needs are. And with a looser housing it would be good to be paired with a higher stall converter that way your not constantly falling off your charger.
