Col 10's lbz thread
clrussell
pro-procrastinator
Sep 23, 2013
5,954
421
With this wheel spacers, did you have to trim any of the studs?
Yes with 1.5" you'll have to trim the tits off the ends of the studs. Just cut all the way to the start of the threads.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
The front track is 2" wider on the front, by adding 2-1-1/2" spacers you have added 3" and making it 1" wider on the rear...
Now that makes a little more sense, you made it sound like adding 1.5" spacers on the rear will only make it 1" wider... 1.5" + 1.5" = 3" that's what I was getting at.
Although that may or may not be correct( I havent measured WMS to WMS before to verify) the 1.5" spacer still makes it look the best any more it just doesn't look right. And any less you will be cutting over half the stud off which doesn't I've you much threads left.
