Im going to be building a truck and am wanting to run coilovers in the front and a ladder bar with coilovers in the rear. Who is running this setup? What shocks are you using?
Why would you go lighter and softer?
It feels pretty good but I would like a little lighter spring because my truck is lighter then most being a RCLB. Also shorter so I would have some adjustment up and down. I can go up but no farther down.
The kit that DB Rods sells comes with 2 different spring seats (cups) that the spring sits in . 1 is for a lower ride height the other is for a higher ride height with the same coil spring , but by no means designed for lifted trucks . I don't even run away bars and my truck corners great I'm guessing because of the adjustable dampening . I have a set of Helwig bars for it 1 1/2" front and 1 5/16 for rear IIRC but decided against them due to trying to stay as light as possible .
What word you call yours in inches dropped from factory height. Can you get a shorter spring but keep the same spring #
