Coilovers!!
PACougar
2,105
41
El Dorado Hills, Ca
With your 6" front drop in your signature what else did you use other than the coil overs? Any one ever run these shocks without springs and with the torsion bars?
I have drop spindles. Why would someone want to run an expensive coilover with no spring? You could just buy a comparable shock if you want to keep the torsion bars.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
The way the valving works on the Rancho's, adjustment only on the compression side, the rebound is too loose. The QA1 shocks have both compression and rebound adjusment but not heavy enough for a daily driver 2500HD truck from what I have read
PACougar
2,105
41
El Dorado Hills, Ca
I ran QA1's on my truck for 60K miles and they still worked perfectly. I'm sure you can find something that would suit you, without having to go to a coilover minus the spring.
Fandango
Aug 7, 2013
54
Mefis
The way the valving works on the Rancho's, adjustment only on the compression side, the rebound is too loose. Before I installed the rears I worked them up down on the 1 and 9 setting, no change on the rebound that I could tell...
The info material states that the valve controls both circuits. I'm not sure how well it works on the rebound circuit though. Even with playing with the knob, when my truck unloaded, the rebound feels loose as can be.
5,817
The rebound is firmed up when the rancho knob is turned up as well compression. It's just not near as much as compression for street comfort. They are also made for more vehicles than one as well as more situations that one. due to this, our heavy springs make it seems like there is no rebound.
It's like buying an edge juice box vs a custom tune for efi live from someone one ;)
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Well, driver side and passenger side jounce frame mounts are cut to make more room for the coils, split the spindles from the UCA, mocked everything up, upper adapters will be here tomorrow and will have the truck back on the ground hopefully. Gotta preload the springs and set the compression/rebound and go give it a test launch. Being able to control the rebound is going to help a lot.
If all goes well, bringing the trailer home and taking it to the track Friday night.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Awesome! Can't wait to see how they fit and perform.
yellowchevy
1,926
82
Louisburg, KS for now
Glad to see you're doing this to your pickup Brian.:thumb: One step closer to custom!!:D
I'm sure you're sick of James opening his whorish mouth about it!!!:roflmao:
Yellowchevy
5,817
Yellowchevy
hey you both like my whorish mouth! :rofl:
Unfortunately install is easy, dialing in is what takes time.
true for most but with where i want him to start with the shock settings from watching some of the fastest trucks around launch, i think hes gunna be close. its certainly going to stop front end lift his first time out :D
PACougar
2,105
41
El Dorado Hills, Ca
Gee whiz a James, tell us more about your whorish mouth:D
