cognito
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
anybody have cognito 4" lift on gmc classic and what tire wheel combos
To answer your question...yes, many of "us" have a cognito 4" lift on a gmc classic
But to get the answer youre looking for, You'd probably have better luck searching google images...
What is your goal here and why are you asking?
There are so many different ways to set up a lift that there are going to be a ton of physical and visual variables within your inquiry...what exactly are you asking for? Pictures? P/N's? What are you looking to do with the lifted rig?
Are you wanting "a look" or are you trying to make it legitimately stronger and better for sled pulling or wheeling? Or, all of the above?
There are many threads in the archives here on this exact topic with pics, parts lists, explanation of torsion bar settings and how to trim the wheel well as well as wheel and tire options...:thumb:
MTNMAX
Sep 9, 2015
11
casper, wy
what I'm looking for is a tire and combo that fits well, would like to know what others are running. Started out I wanted to use stock wheels with 285/75 16 but tires rubbed on kryptonite uca's pic #1. I now have m/t 16x7 with 3.62 backspacing but I don't like the look of tires sticking out so far in front, I do need clearance for chains also. I have tried calculators but would like to see some pics with possibly 17x9 with 33" tires. I need to replace tires and there are more options in 17's. cognito recommends 8-10" wide with 4.35-5.15 bs I tried 4.5 and had probs with chains but possibly going with 17" I may gain clearance
POWER Freak
Nov 20, 2008
46
Idaho
It's not a GMC but I think you coulnd get the idea. This is a cognito 4-6 set at 4". 18" rockstar 2s with 33×12.5 R18 Toyo MTs.
