Cognito A arms
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
Thinking of going with a set of cognito A arms for my truck. And am wondering if anyone here has them and if they do are they smaller than stock A arms or about same size, bigger?? My tires rub my A arm at full lock now so curious if these are a little smaller may be better for me. Thanks
CarolinaHD
969
NC
Used to run 315/70 and it would rub stock arms but not the cognitos. Still hit my sway bar though.
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
I'll try and take better pictures tomorrow ol lady took these
5,933
Your immense amount of back spacing from those hummer wheels is not helping you. I would go with a wider spacer (assuming your running one)
5,933
Different wheels may pose more issues with you trying to fit those 37. Switching to a 1" spacer ought to solve the issue but I would put the cognito arms on first, then see what kind of space you need. You may run into firewall/rocker panel rubbing issues with less backspacing though.
Personally I think it looks good with those wheels on it. You don't see that damn near at all.
AJH
257
Memphis TN
You are only the second person I have seen run 37s without a lift. I would do what James said, a different wheel will have you hacking up everything.
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
I just don't like the ride it's rough I could try and change tires before going to a different wheel I need to clean these rims up and paint them maybe do chrome bead lock nuts.
dirtydmax
<---up shit creek
Sep 1, 2013
1,091
46
muskoka,Ont Canada
Do the cognito upper a arms lower the stance at all or are they just for runing larger tire wheel combos?wanting to lower my front 3-4" so curious if keys or arms would be best.Sorry for the hijack Defiant.
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
They are for leveled trucks to make that upper balljoint angle straight to take the bind off them, and the smaller tubes give you more travel before hitting the bump stop for the arm.
Pretty sure brian ran them or his lowered truck but they may have been djm, can't remember.
moparkxracer
2,309
33
Out and about
I'm running the tubular Cognito ones on mine. I'm lowered abt 4 inch up from, I had to flip them sides and mount them upside down. I think they are a little slimmer in the area where you are rubbing not my much though.
