So here's the mods to date
PPE STUFF
manifolds and up pipes, deep transmission pan, deep rear diff cover, oil centrifuge, transmission cooler, high flow CP3 kit, ported rail fittings, FPRV shim kit w/2 washers, triple gauge pod w/ boost pyro and rail pressure gauges, silicone boost tube connectors
COGNITO STUFF
4" NTBD drop lift kit (set @ 4" c/v angle is 2.4*)tubular upper control arms, idler pivot assembly, pitman and idler pivot braces, HD sway bar end links, C/V 4x4 driveshaft, 2" DEAVER mini packs, bilstien 5100 shocks
ENERGY SUSPENSION SYSTEMS master poly bushing set
RARE PARTS Diamond series drop forged tie rods
MOTO METAL FORGED 18x10 wheels wrapped in TOYO at2 285/75/18 (34.8" tall)
SSBC Big Bite brake rotors w/EBC yellow stuff pads and stainless steel braided brake lines front and rear
HELLWIG sway bars front and rear
AIR RITE 5000 helper bags
K&P ENGINEERING/SCOTT's PERFORMANCE 12 micron absolute lifetime oil filter
CALTRACS 4 hole adjustable preload traction bar system
Alligator Performance 5/8" trans cooler line upgrade, resonator and pcv delete plugs
ALLSEASON DIESEL/DHD
3" one piece y-bridge
Stainless steel braided high pressure steering pump lines
DRP Fuel sump
AIR DOG 2 165gph dual filter lift pump
FUEL FILTR HEAD DELETED
ARP 2000 Head stud kit
GARETT 4094 vgt
Diamond eye 3" down pipe, with custom bung to evac pcv
Diamond eye 4" quiet tone exhaust modified tail pipe int over axle down turn
SDP egr delete, modified to fit y-bridge and BD intercooler
BD cools it extruded fin intercooler
Polished hot side intercooler pipe(stock)
BANKS POWER
Ram air intake and super scoop
ULTIMATE TRANSMISSION performance built transmission w/proprietary clutch packs, billet input and output shafts, billet P2 hub and custom valve body(800whp rated)
SONNEX transfer case pump rub eliminator kit and TRANS/transfer case brace
SO CAL DIESEL 1 piece billet flexplate
YUKON GEAR 4.11 gears and master axle rebuild kits front and rear
EATON DETROIT TRUETRAC
DURAMAXTUNER tuned, S.P.A.D.E King tune, optimized TCM, key lock DSP 5
Billet grille
Digital 35w H.I.D's(headlight and fogs) PIAA 60w(high beams)
Stainless steel full length 3" cab steps
PPE STUFF
COGNITO STUFF
DRP Fuel sump
GARETT 4094 vgt
BANKS POWER
Billet grille
