Chum Again
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
Well, this has been a while in the making. I finally had to take a month off work so it made sense to get to work on the truck.
There are a few parts to the project. Short bed, McGauhy's 4" rear drop, Super Coils front 3700 pound coils, Allison Build, custom drive shaft, ARP studs, 110HP injectors, Garrett BB turbo, MBRP 4" turbo-back exhaust, new cab floor, Automatic steering column, complete LS interior with Katzkin leather, Adrenaline 4K tuning upgrade, enough B-Quiet to hear myself think in the cab, POR-15 the frame and most likely new 110LB springs and pushrods. I'm sure I forgot something.
Parts!!
First up, short bed conversion! I will have to put some pictures of the new bed in later. I found a short bed step-side in summit white. I ended up getting with the step-side bumper and all for a song compared to what they are bringing. The drive to get it and back could have been better.
This is also the first project in our new shop.
Hood and grill removed. Oh, I noticed the sway bar was broken in half! Those are so not cheap for what they are.
Bed, springs and axle removed.
For those that have not removed the amazing wax crap GM was so kind to grace our frames with; BUY A MEDIA BLASTER! That junk fills pads and wheels like a champ. I spent 6 hours scraping and grinding the frame. I still have a lot to do. FWIW, the Marine Clean that POR-15 recommends cleans about as well as Dawn dish soap.
Getting the spring hangers off is a chore. There are eight rivets and it's a PITA to keep from getting the frame really hot while burning through them. The grinder and a big punch helped a lot. I still have to tackle one of the rear shackles as the sleeve and bolts are bonded to the bushing.
The cut is made 14" forward of the mid-section.
My favorite tool!
Yes, that is a Milwaukee Portable band saw. The cut is pretty clean for working on a frame.
We put the frame back together today. I still need to cut the second row of bed mounts off to move them.
I used the 2500HD short bed conversion instructions. The process requires removing the factory splice in the frame. The mid-section, or splice, overlaps the front and rear sections and the tank and shock support runs through it.
This is what it looks like when you cut the rest of the mid-section out. Not just a straight cut.
Then, with some help from a friend here, the frame was welded back together. You can see that we just took the splice out and made the short bed the same way the factory does.
My new 3700# coil springs also came in today. As well as my Katzkin leather for both Chum and Slick.
My new 11.50" rear should be here Thursday. Thanks Tony.
13,701
756
An air chisel and punch works awesome for cutting rivets and removing them.
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
I agree. We used them both. The spring hangers had eight apiece. The hot knife worked the best.
Cutting the bed mounts off is a real PITA!! I have no idea why they welded them so well. Cutting the mid-section out was easier.
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
More front end
I had to buy a new wheel hub assembly and tore into the brakes. I learned a valuable lesson. Some early 2500LD trucks use 1500 series brake hoses. That was fun learning the hard way.
Old 2800# coil springs
New Super Coils 3700# springs installed
I will have the front back together tomorrow morning, save the shocks.
Oh, my new 11.50" 14 bolt came in today. Now if only I could get my bushings and the one bolts I had to torch off for the leaf springs.
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
Allison build
Once I had it up on the stand the break down began. It gets tanked tomorrow and back together.
She was pretty clean for 225K.
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
Cab ready to come off
I got everything ready today. I will have the cab in the air in the morning. Hopefully, the motor will be out tomorrow as well so I can replace the oil pan and pump.
GM ECM and harness. Yeah, it goes back in.
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
Cab came off
I took the cab off today.
I had to cut another 4" off the rear of the frame. Yes; the bed is slid forward.
Shortbed Step-Side teaser
AAM 11.50 rear
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
Rolling Chassis Today
It doesn’t look like much. The spring hangers will be welded tomorrow. The measurements take forever. I’m pretty sure at this point the frame is probably closer to true than it was from the factory.
I spent a lot of today pulling rear brakes from the new axle. I will be busy tomorrow taking the axle apart to fix it.
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
A bit of progress
More new parts
My new borescope. I did lots of looking around in there before I pulled it out.
Blown Head Gasket
Motor Pulled
Frame to carwash
Frame prepped
POR 15 does not stick to bare metal worth a crap! It does; however, stick to skin very very well. I wasted a lot of time prepping the frame. DO NOT USE A BRUSH! I pushed the stuff all over the frame and got it everywhere. I spent $48 on an HVLP gun and had it all done within an hour.
Frame POR-15
Oil Pan
Motor Prepped
Mag-Hytec Cover
z79outlaw
793
Salem WI
Looks real good, you sure are right about that POR-15 being some nasty stuff, media blasting or a wire wheel on the grinder really eat that wax coating up.
BombDocDiesel
Army Bomb Squad
May 20, 2009
368
Belcamp, MD
I ended up using wax/grease solvent. It's actually the same composition as lighter fluid; just wipe it on and let it sit for a few, then wipe it off. That wax kicked my butt for two days.
