Help: Changing Regulator, PITA!
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Swapping the stock location Fuel Pressure regulator on my truck (LMM) tomorrow night.
any tips. Looks like it is going to be a PITA.
I also have a dual fueler.
Anyone wanna help, lol.
I have beer.
slowlmm
Mar 2, 2008
2,582
46
so cal
I have beer.
mabey I can tomarow mike. I will call u in a bit unless you want to drive down here :D I will swap it out for you should take about 3 hrs
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
hahah, come on up Tommy! was gonna do it today but the part didnt show up last night, it got here this morning, I gotta go pick it up, Prolly try to knock it out tonight, or tomorrow now, lol.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
been there done that. not fun. watch out for the o-rings on the lower intake manifold and also watch out for the ones on the thermostat housing. 25 bucks a pop for the ones on the lower manifold, and there's 2.:mad:
I had pics with it all pulled apart but i don't know where they are.
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
IIRC- This is the mod that has the little SOB torx on the backside of the CP3... if so try a 8 or 10 mm box end wrench with the torx bit tack welded into the box end.
Good luck!!
slowlmm
Mar 2, 2008
2,582
46
so cal
Here is the procedure from all data For lbz/lmm
super diesel
<<<< Under Pressure
OOO!!! I only remove the top coolant crossover pipe (the metal one going to the thermostat housing). But then again I made a special little tool to get to them. Yea. Thats a 1/4" drive.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Ill do a DIY but I am still not sure thats the problem. Also I have purchased a box of torx-25 for the job, I twisted 2 already changing the reg. in my 2nd cp3 :D
NelsonDiesel
Formerly StewieTuned
May 8, 2008
896
41
Buena Park, CA
www.NelsonDiesel.com
they are really not at all that bad....
drain coolant
remove black pipe to thermostat housing
remove intake piece that goes into intake inlet (crossover)
remove the intake inlet into the crossover
remove rubber hose to cp3
remove the 3 FPR bolts
real straight forward explanation but when you get down to it you will see. Of course i left out some things that need to be pulled in order to remove the above stated pieces... but these are the major objectives...
super diesel
<<<< Under Pressure
drain coolant
Not that bad,,,but not that fun either.
You left out the importaint items. Box of Puffs (during the changeout), and the 12 pack to celebrate when done :D.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Well it was not the regulator.
The fuel heater stays on all the time.
I need to find out what commands it, because it always has power to it to keep it on, even when truck is off.
