**CHALLENGE** - TURBO LAG TEST using a log
jkholder09
Jan 8, 2012
1,188
Maryland
And guys that are new and looking for upgrades.......well my opinion of streetable vs yours is way off and very subjective.
I will get some logs and videos for you. I would like to show it both ways. As in a bad setup and the truck setup properly.
from mobile
13,748
821
The most important thing is that you're happy with what you have. I know Russ was pretty disappointed with the response of his setup when he put it on because of what he was expecting after reading posts by people who had the same setup. All the info you want to post will only serve to help those considering an upgrade make a more informed decision.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Quick video I took last spring. It's not stomping on it but you get the idea without a downshift.
Just like what Justin said. Rolls some smoke and doesnt really come alive until after 70mph
My Airdog pump showed up last night. I will get some logs later this week.
http://youtu.be/al4MpKY2fk4
275/65/16s
900'
Bullseye s375/87/.90
AAT ~75º
Dirtymaxx03
3,109
275/65/16s
900'
AAT ~75º
If you're cruising 75-80, does your turbo light instantly?
I know if I'm cruising about 2200-2300 rpms and I punch it, it spools damn near instantly. I love rpms lol
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Truck wont hold 5th to do the test. Messed with the tcm and no luck. I love messing with this stuff but when I cant get it to work I feel like a dodge guy (mentally handicapped). I'm a noooooooob.
jkholder09
Jan 8, 2012
1,188
Maryland
Turn all the shift rpm and speed to 0 up and down except 5th
U will start in 5th
Good dyno tune
from mobile
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
That makes sense. Is that pretty much the only way to do it?
Edit- If make those changes to only pattern b (tow/haul) will it work?
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
http://imageshack.com/a/img838/6288/8kp3.png
1500 roll to 20 psi
thanks jkholder
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Towing with my twin set up is amazing to me. Smoke free! There are things I don't like about my setup, but towing just flat gives me a chubby!! The heavier the load, the better it feels!
Just took this driving to my parents for Christmas towing my trailer weighing around 11,000 or just over.
[YOUTUBE]P754EmFr_1A[/YOUTUBE]
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Anyone else have logs? I'll put together a list inside this thread as soon as we get enough results to start comparing. Please to to get both test logs.
I would love to see a single 366, stock/475, 4094, 472 etc that seem to be common but whatever you have is fine. We need a couple stock turbo base lines too.
Andrew
Costly Obsessions
Aug 7, 2013
275
delaware
subd im thinking of ditching my vvt an going to a fixed so hopefully this will hold great info with the fixed singles :thumb:
6,032
I just took some a few hours ago. Soon as I get home ill up load the screen shots.
Surprisingly the time to hit 20psi ain't far off from you guys with 366 but my ramp up from 0-20 is much more linear.
