Catipillar motor.
03maxpower
Jan 20, 2009
327
somerset, pa
a guy around here has a dt466 in a ford and his trouble is getting the power to the ground and he is running 34x18 super pullers im sure caleb knows who he is.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Yep, His name is Frank piscarish (not sure on the spelling there) but its close!! I havent seen that truck in a few years though?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
2400 and 4000? seris allisons are the same as the 1000 but stronger
no adam..
the 1000 and 2000 series (that includes the 2000, 2400, 2350, 2200, etc) are "identical". They have slightly different gear ratios, a different converter, and thats about it AFAIK. Almost all parts between the 1000 and 2000 series are interchangeable, save for the planetaries because they have different amounts of teeth to net the slightly lower ratios.
Some 2000 series transmissions dont have a park pawl, but thats really the only "big" difference.
the 3000 and bigger allisons (along with the AT series) are completely different than the 1000/2000
ben
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
If you want a big engine to put up front and are willing to sit back about 2 feet, a 12V92 Detroit 2-stroke can be put in an F-250 and turned up past 2500HP. It's been done.
13,735
804
I think it is but not sure if the 12V-92 is a 2 stroke or not, but the 2 stroke Detroits sound BAD-ASS!
FMOS
Hard Up
Nov 19, 2008
352
Fort McMurray, Alberta, Canada
DT466... might be able to find one of those in a school bus for cheap.
Lots of guys use those in sled pull tractors dont they? I recall getting an email of a tractor that had a 466 and the headgaskets didn't blow on it... it split the block completely about 3" below the head.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
THe old Buzzen Dozzen, Its hard to beat one of them old boat anchors!!!
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Pic:
When you consider the engine weighs 3900lb, who needs hanging weights?
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
In theory they have to have the superchargers on there, otherwise it wouldn't run. I'd say they're in there somewhere.
Yeah they need positive manifold pressure just to run normally, They usually stick up way further than the "valve" cover though, Id like to see how they are doing that, way cool nun-the-less!
Noreaster
2,910
Cape Cod,MA
they have air chambers that dump into the cylinders, pistons act as a valve so no intake valves in the head.
The big scallop boat I worked on has a 16v-92 TT around 800hp, the HO 16v-92s had quad turbos & made 1600hp
All the 12 & 16 cylinder motors are 6 & 8 motors bolted together
