Cat fuel filter mod
$chultz38
230
5
They won't work with the wires unhooked or cut. They are a normal open circuit the little float raises with water in the bottom of the filter and then closes the connection and that makes the light come on in the cluster.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Thank you captain obvious.
What I meant was I ripped everything out because I've never seen it work before and I'm convinced they don't work
Duramax52513
Jun 23, 2013
99
The link that one of you guys posted from nicktane said you don't have to plug in the WIF sensor you just tie it back
Duramax52513
Jun 23, 2013
99
So I can still do the mod and not hook up the WIF sensor and evrything will be fine? The truck just won't tell me if I have water in my fuel or not? Will that cat mod still take the water out of the fuel without the sensor hooked up, sorry I'm asking so many questions I just don't know much about diesels as this is my first one
Does the water only get separated if you have an actual water seperator?
Duramax52513
Jun 23, 2013
99
Cat sells a water separator that attaches to the fuel dilter mod so I'm looking at that but not sure, I deffinetly don't want to go with out the water separator capability even if you guys say it doesn't work anyway knowing my luck my truck will be floating haha
13,736
806
I looked a while back and didn't see any filters from Cat that separated water, and I couldn't find any of their water separators that had a very small micron filtering capability. Just run a Donaldson filter on the adapter, and you'll be set. I think the Donaldson is a better filter anyway.
9,905
151
I'd just buy a FASS or something with the water separator built into it and run the regular two micron CAT on the stock head. Best of everything that way.
