Does any one use the cat fuel filter mod that works with the factory setup, I've heard there much better filters but just wanted to hear it from you guys if it was worth the $90-$130 to buy, the other thing is the filters are only $20 compared to the $60 for the oem ones.
If you do run this does your truck have the W.I.F sensor and does it hook up to the cat fuel filter mod? Not to be rude but I don't need a lift pump right now so I'm. Not looking for guys to just say but an air dog and you'll be set.
Thanks for the input in advance
