Cat filter worth it or not
wymax
Sep 15, 2016
25
wyoming
2008 Chevy 2500hd duramax stock
Try to get a idea of what filter to use.
And best way to clean injectors
Sent from my SAMSUNG-SM-G870A using Tapatalk
Budneeds2beers
Aka Mike Honcho....
Aug 25, 2016
497
Cali
I just did the cat adapter. Its nice but kinda a pain in the @$$. Make sure you remove the check ball and use the cat filter only. I didnt use cats filter and found out that you need a different oring to seal it or it drops head pressure. The filter sticks to the adapter when changeing it and dont pay fot the spacer just get longer bolts and two nuts to fit over the bolts for spacers. Also you cant drain the water from the filter unless you remove the filter.
wymax
Sep 15, 2016
25
wyoming
Just looking for a way to clean my injectors but that's that did help what the best lift pump out there
Burn Down
Sep 14, 2008
7,092
Boise Idaho
True but the micron rating is higher
That's why you run both. I prefer to let one type of filter do it's thing and the other what it was intended for.
OP, as far as lift pumps go, I have been running a BD flow max for about 5 years with out a hitch. The PPE died at about a year, Dan offered to look at it but I just never sent it in. Personally I think Fuelab Velocity might be the best pump on the market.
BrandonLLY
116
The donaldson filter is low micron and separates water.
9,903
149
If it doesn't have a drain on the bottom or a place for a bowl to drain water it's not a water separator.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,492
472
Central OH
I started running the Donaldson P553203 with the nicktane adapter. Never had any issues running the cat filters either.
