cast or forged pistons
The Funk
May 3, 2009
220
southern indiana
Doing a build this winter and was still up in the air on what piston to run. Its not going to be a dd but will see some street use. I'm leaning more towards the forged arias and was wanting to know how Meany miles people were getting out of them. Its going to be a big single truck with a lot of spray wanting over 1200 hp
13,752
822
Definitely forged if you're going for that kind of power unless you want to shell out the $$$ for Monotherms.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
If you were going to be in the 750-850 range id say Mahle race performance cast or Fingers new pistons. But with your goals I would definately go Arias forged.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,545
528
Central OH
I still vote for cast, depending on how often you spray it. Aftermarket cast pistons are still very strong, even most of the high HP Cummins guys still use factory cast pistons at that power level. I understand its a whole different animal than a Dmax, but they still use Mahle pistons...
quadracer37
Mar 31, 2009
547
northern, IL
The aries are Better suited for pulling/drag only app I would use the Mahle forged for street use. I'm still up in the air what I'm going to put in mine this winter between fingers cast mahles or the forged mahles.
JDub
607
Hooper, Utah
Colby at Adrenaline Performance is running the Mahle Forged pistons in his LB7 motor, believe it's in the 800 on fuel and 1050 on spray range. Last I talked to him, think he said he had about 40,000 miles on the motor. I'm curious to hear how long those pistons can go before running into oil consumption and ring issues...
quadracer37
Mar 31, 2009
547
northern, IL
the mahle forged are made of a different grade aluminum then the arias and ross. they dont expand as much after warmup so they do not require as tight of a piston/wall cleareance. its the cold starts before the pistons are expanded that really puts the abuse on them. a street driven truck may see 3-5 cold starts a day where a competition motor might only be once or twice a week thats why they dont last as long in street trucks. Guy has almost 80k miles on mahle forged, he told me that he has seen some street motors barely get 12k before they had excessive blow by with other pistons.
