Casper the Nerd
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I love it! never did like the exhaust on the side ( sorry Casper )
So are there new rear springs on the back and hangers?
Casper looks WICKED
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
Casper needs some type of stack for sure. I am really not a fan of dropped vehicles espically a 4wd. I want to drop snowflake and give her the mean Clean look. But i still have not decided rather she will be used for pulling or drag racing. To bad i couldnt do both:eek:
slowlmm
Mar 2, 2008
2,582
46
so cal
u can look at casper
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Casper looks WICKED
Well Casper was never a fashion statement ;) But, he never got a bogus slip for smoking out the lights either :D
Pat will have to answer te other question :baby:
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
Allison just why I was playing the theme song for George Lopez :rofl:
:rofl::rofl::rofl:
So did my Grandson...I was going to show him the album, but couldn't find it...I must of had the 8-track:eek:...which are all gone now:mad:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
how much back spaceing do you need ?
If I could find a couple of 18x8.5 or 18x9 rims with 25mm or greater offset (positive offset), it would save me some money and let me go faster.
Here's the problem, the tires I have are 32.5" dia 18" tires. They won't clear the wheel wells with the truck lowered. They have about 10mm offset. I can get more offset with 17" or 20" rims, but can't find tires that are as tall.
I will have a similiar problem up front if I want to lower it using drop spindles: I will have to change rims to 17" or larger, and can't find suitable small diameter tires to use.
The truck was lowered by notching the frame, beefing it up, then flipping the leafs.
Cornell
LBZ for life
Sep 11, 2006
1,601
Minnesota
You could tub the rear :D
ripmf666
15,123
14
47
Wentzville Mo
I mentioned in another thread Casper looks like a low rider with hydraulics ready to start hopping :eek: :rofl:
Hopefully we will find the right drop spindles for the front end soon. Sorry indoor pic is crappy :(
Edit- Little white cars should not pull to close behind like yesterday.:badidea: A car got between us yesterday when I was following Pat back to the shop :rofl:
Hey Kat you might find what you need for the front end on these links, This is the kit om going to use on my truck and try 18" or 20" wheels and nitto tires,
PDF file shows what front looks like
http://www.djmsuspension.com/Instruction%20PDF%200908/ControlArms/CA2602L-3.pdf
At the top of this link is the list for the 3/5 drop and Part # and prices
http://www.djmsuspension.com/applications/chevy%20apps.html#heavydutys
Noreaster
2,910
Cape Cod,MA
Bet your wishing you stuck with the 1st casper with 2wd. Probably wouldnt be that hard to lose the front axle & transfer case.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
The 2wd and 4x4 trucks are identical up front. Just pull the axles and diff out, and you are 2wd.
It's alot safer and easier to drag race in 4x4, so we will keep it 4x4 for now.
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
looks good. have you looked into billet wheels, Intro Wheels can make them in any offset you want. also what about a 22" wheel, as long as the tires have the speed rating you need you can get them in a varity of sizes. and w/an offset like mine +20 6" bs, they will tuck w/o rubbing. have you changed out the keys yet? the mcgaughys keys will get you another 1-2" in the front. you would just need to change the tranny x member if you haven't already.
22x9.5 Black 3420(LR) +20mm 8x6.5 6(BS) 130.81mm
