So what do you do about adding weight to the truck? What do you use? Where does it go? Sorry if this is a bit off topic. Maybe it should be started in another thread. Just curious as to what some of the things you have to do to the truck are.
Thanks.
Three ways to do it:
Remove weight from in front of the front axle. This shows the least increase in rear axle weight, but it also reduces load on the front tires, reducing rolling resistance.
Put weight in back, in front of rear axle. This improves the stability the best but puts slightly more load on the front.
Put weight behind the rear axle. This unloads the front, and magnifies the weights effect on the rear. Like 100lb might = 110lb. But it can hurt stability if you go nuts.
#1 is always a good idea for all kinds of racing. #3 is the most bang-for-your buck.
#2 is good if you already have stability problems. (spinning out)
