Carrillo Rods, Cut and coated pistons,Bearing gaskets and Turbos No Group Buy Or Sale
06dmax
Aug 5, 2009
295
price on rods bearings and coated pistons also include the part numbers on that stuff so i can check them out and get all the info on them thank you!!
5,933
Can i get a price and availibilty on std bore LB7 piston rings for stock pistons? thanks guys :D
warpspeed
Shadetree
Feb 10, 2012
45
Ohio
08 LMM....needing
1 stock piston
Rod & Crank Bearings
8 ringsets---is there ANY available? aftermarket or stock
overhaul gasket set for block/heads, w/manifold/uppipe gaskets, no valve seals needed or valve cover gaskets.
pretty much need all the stretch bolts
Injector o-rings/copper rings...8 sets---also a price on new lmm injector tips (each)
oem Left motormount---rubber part
OEM LML Drivers side manifold
LMM EGR Delete tube
Aftermarket downpipe, clamp for top of downpipe
if you have any input on the gaskets I need...or any i dont need I'd appreciate it.....I'm willing to buy a Metric 0-ring kit if that would really cheapen it up.
Thanks!!
