Lb7 > lly.....
Back to the pos lb7 tho...... I replaced bcm got half as many class 2 codes truck still won't flash not sure if the bcm needs to be programed to the truck first or if they even can where it won't tune the ecm. I'm getting codes for the restraint module believe it's under drivers seat and the carpet.... could that be shorted out?.... I don't have a airbag light on nor does the fix say service air bag?
I got a new fuse block to try our next as well as I had a loose fuse that I tightened up so we had a good connection. But maybe something in there is causing a issue? I'm running out of ideas. Anyone have a diagram of the class 2 stuff or ways to jumper around things to help try eliminating modules
