Can't afford a trailer?
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
I'm sure it would. Most places if it's wheels are on the ground it needs to be registered.
IIRC, in Az the "trailer" is covered under the tow vehicles policy while attached.
550
built mine for less then 200.00
class V A-frame 2 5/16 coupler rated for 15,000lb, class 2 turnbuckles 3/4" bolts and hitch pins, 20' of 3/8" chain 10' of .316 wall DOM 2 5/8" tube
hitch is upside down in this pic..
i could back up.. any sharp turn ment shoving/scrubing the front tires.. thouhgt you can trun pretty darn sharp though
i taped a flat 4 in to the 75s running lights, brake and turn signals.
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
This tow bar made Bonneville and El Mirage LS racing very easy at starting line and pick up . Takes only a few seconds to hook up and get removable pins locked in or out . Trick little set-up . Both arms adjustable with a levers on hydrolic arm . It doesnt have to be perfect back up either and can be off in each direction a bit . Makes for easy hook up . It self aligns when you pull away .
Best part is when you diconnect it folds up behind tow vehicle and locks in place folded to the side .
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
I thought u couldn't tow and ally very far without it running. This would be a neat little set up for snowflake but i no the second i buy this and do not take a trailer the rear end is gonna lock up:D
9,903
149
B.C.
That's why you put the transfer case in neutral Kurt.
9,903
149
B.C.
Not as pretty but it got you across the country didn't it Mr. Clampett!:rofl:
maine04max
Dec 11, 2008
1,009
I noticed in the pics of blue there are 2 recievers on the sides . is this for a bike rack or something??? just curious but it does look like it could be used for a rack of some sort . and is this a bolt on kit or a custom thing ?
thanks craig
