Cannot open clipboard error message
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
If the file is attached to another application, Windows will halt requests until that application "releases" the pointer.
Close all other applications. Reboot if necessary.
I hate windows. :D
The Neens
BFD
4,596
Monrovia, Ca.
I'm kinda thinking it's my awesome new Toshiba laptop:rolleyes:
1st time was last Sat., I closed the tuning tool, re-opened and it worked...Today it will not work...I'll try the re-boot...
The Neens
BFD
4,596
Monrovia, Ca.
Uninstalled and Reinstalled V7 & V8, no luck, clipboard will not open...Tried the auto-update for each and I get a "bad secret code" error message...
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
If you have 2 instances of EFILive open does it work?
A) Target Tune
B) Source Tune
Highlight cells, CTRL+C, move to Target and paste?
Can you copy things into Notepad or paste from Notepad?
Trying to figure out if it's Winblows or EFILive.
The Neens
BFD
4,596
Monrovia, Ca.
As soon as I click Cntl+C, I get the error message...Same result if I highlight the entire table and right click Copy...
This is a Toshiba with Vista...Hard drive, memory and "system board" have been replaced since purchased new in June '08...
9,903
149
B.C.
Maybe it won't let you copy because it is the secret tables which have a secret code??:joker:
9,903
149
B.C.
If your in Demo, this could be your problem because I don't think you can make changes to .tun files when in Demo. Or save them.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
Apparently I'm not smart enough to open anything in Notepad...I can see all my tuning folders, but can't get into them...
I'm also stuck in Demo cause I don't have my V2:eek:
I tried it in Demo mode and it works on this XP computer.
Open any other application that allows typing.
Type something, then highlight it and go CTRL C.
(CTRL-C is actually retarded, that used to be the ASCII code for program halt)
