Can we get Race valves through you Pat/Kat????
BigWill_21
~BULL HURLEY Look-A-Like~
Aug 28, 2006
193
Greenville, NC
Race Valve install issues.....
We have an event here in about a week... i figure I shoudl at least get the race valve until I can decide where to go next!!
So, Pat/Kat do you guys carry them or should I just order online from PPE???
BTW: Which is prefered the RACE VAVLE or the SHIM??? I woudl rather VALVE than SHIM!!! Seems simpler!!!
Thanks
WILL
BigWill_21
Aug 28, 2006
193
Greenville, NC
10-4...
I've got it coming then!!!
I may need to get some install instruction though!!
I am scared to mess with High Pressure Fuel Systems!!!
BigWill_21
Aug 28, 2006
193
Greenville, NC
THANKS DAN..
I got it shipped 2-day so i hope to ge tit Friday for a Weekend install!!!
I plan to get your Fuel Rail and Duel Fuelers as soon as a Tranny is in the LiLLY Pig!!!
THANKS AGAIN,
WILL
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
Will, can you please pm me your last name so I can make sure it shipped out and will be there in time? Thanks
Dan
BigWill_21
Aug 28, 2006
193
Greenville, NC
Well Race Valve is here, but I cannot install it..
I cannot get to the rail to remove it...
I removed the Black Box and underneath the bolts are not reachable by any means I see available to me.. Especially one on a bracket running parrallel and somewhat underneath the rail!!!
The pictures in the PDF aren't liek the brakcet on my truck!!!
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
Will, are you looking in the correct spot for the valve? It on the rear most part of the fual rail on the drivers side?
Dan
BigWill_21
Aug 28, 2006
193
Greenville, NC
Dan
Yes.. I can actually get a wrench on it somewhat but there is no way to unscrew it or remove th eplug formt he rail becuase of the black brackett thta is underneath the glow plug controller box..
Red Arrow is Fuel Rail Plug...
Yellow arrows are the Bolts.. I only have 3 instead fo 5 and htye are under the bracket.. Not on top!!!! Liek int he PDF you sent me earlier!!!
Sean8816
Junior Member
Aug 8, 2006
I came across the same problem...my bracket was different from the instructions. I rounded off 2 of the bolts trying to break them loose...because they're impossible to get to. Cutting the bracket off is the only way I'm getting that thing off my truck.
BigWill_21
Aug 28, 2006
193
Greenville, NC
OK, good I am not crazy then!!!!!
I believe Since my LLY has such an early build date.. Mine is a Feb. 04 truck, that they changed designs for this exact reason!!!!
DAN... You may want to take note of this for you website, and modify the PDF How-To-Installs to show there is a different bracket!!!
I will chekc my Dads LLY today.. He also has a Feb. or Mar. 04, Build date truck!!!
