Question: Can u DD an S480?
Shieldsinc
On a Time Out
Apr 24, 2012
321
I wS wondering if it's a smart move to get an S480 on my DD. or what I would have to do to make it work like 100 over injectors or what. Thanks for the input
Shieldsinc
On a Time Out
Apr 24, 2012
321
How's that nos wrkin for ya u like it or what I was thinkin bout a kit myself or water meth
05chevy
1,086
Dustin from diesel addiction DD a s480. But they was a fully built truck. S475 would be ideal
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
i'm running an s480 over stocker on stock sticks for the time being and it works great for me. lights fine and I see around 25psi out of the 480.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
As Bobby said I DD'd and towed (another duramax on a trailer) with a cast S480 with an 87mm turbine. It wasn't instant spool up but it was worth the wait when it shot from 15 to 60 PSI instantly and broke the tires loose from any speed. It isn't something I would recommend someone for a truck they towed with all the time, but you can tow with it especially if you live in a fairly flat area and can stay conscious while towing so that you can watch your EGTs and downshift or accelerate when needed. I also had a cam, headers, and stage 2 heads to help with airflow. A billet wheel would have made it spool a good bit better.
All that said an S366 can easily get you to 700 and will spool much better and be better for towing. A 466, 472, or 475 could also get you there while being much more streetable. What is the point of losing streetability by going with a turbo so much bigger than what you have the support mods to handle? A 480 single will easily do 900+ rwhp.
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
I run a HTT Billet S482 as a single. There is a lot that goes into making it work well on a street driven truck, and I haven't even figured it all out yet. But I will say this, get a good quality high stall converter, a custom grind cam, head work, headers/upipes, big injectors, dual cp3, and someone who has tuned for big singles before. without any of those things, you are not going to like it.
othrgrl
Mar 10, 2008
2,151
Wilmington NC
Right on the money. TCM tuning goes a LONG way for making it easy to run a big single on a DD truck that you tow with. And that is something that really needs dialed in on each truck and combo to keep you on top of the charger under moderate throttle. Precision has a converter that works amazing on big single trucks - it is loose enough to stall to 3300 RPM in 4 HI 1st gear but as soon as you are moving it couples hard so even at idle you can pull or back a trailer up hill. When you jump on it and the converter unlocks it will flash up to 3000+ RPM and give the turbo some initial spool then start coupling so hard that it will actually drag RPM and put a load on the motor to spool the turbo the rest of the way up hard.
