*Edit for clarity* - Truck is a 2006 LBZ with the Allison and has the 263 with the push button shift transfer case.*
I'm having an issue with the truck that I can't figure out. Sometimes, mostly while cruising on the highway for long distances, it will "slip" like it is going into neutral and immediately catch and continue going. It happens sporadically. Sometimes taking 200 miles to happen, sometimes every 100 yards. It sometimes happens if I really hammer on it from a stop, but mostly only highway speeds when warmed up.
I don't have any codes at all, so nothing to go on there. I've thought it could be transmission or FPR, but the symptoms don't really make sense and the logged fuel pressures don't match the problem.
So I'm wondering if there is any way the transfer case can slip? If so, what would I replace to fix that?
I was just in there a month ago to put the pump rub kit in, but I wouldn't have known to look for anything, nor known what to look for. Someone else was in there before me as well, as it was slapped back together very sloppy with orange RTV. I've only had the truck for about 3 months.
