I know your a little out of Ryan but how do caltracs plant the rearend?Also, Cal tracs plant your tires to the ground, bars just take care of axle wrap
When the axle pushes forward on the bar in an attempt to wrap it pushes on the upper triangular bracket causing it to pivot at the mounting point and the back side of the bracket to push down on the leaf spring itselfI know your a little out of Ryan but how do caltracs plant the rearend?
correct, unless you adjust the bar for preload where it is touching the spring at all times in which it will affect ride quality adversely, i plan to make my front brackets shorter on the bar side so i can keep the top further off the spring to retain ride quality, but with the shorter bottom side it will allow for a lot less wrap before slamming the bars down. In theory anyways...Based on that explanation the Caltracs allow for some movement (albeit minimal) until the slack is taken up in the bracket. If I am understanding the workings of the Caltracs correctly.
fwiw yes, but it seems to me that the ride quality comes down to the adjustment and amount of preload in any style traction deviceOk this is why the long bars offer better ride and the caltracs are slightly angled to provide some down force and tration but ride badly.Supposidly
Im hoping to achieve a little more gap than that by distorting the triangle, but still have them hit at the exact same amount of wrap.Preload definitely affects the ride, I sent mine up for daily driving so there is about a 1/4 inch gap between the pin and the top of the spring, then just a rubber hose around the pin to take the noise out. I can also add or remove air from my bags to change ride height, which changes the angle of the caltrac bars and pivot. So I can somewhat adjust preload from in the cab with air.
Sent from my XT907
That really depends on how they are set up. I put some short fixed length bars on the van, and I believe they have been a big help in traction. I regularly get mid to high 1.6 60' times with a very cheap suspension setup. I think that's pretty good for a long, heavy, nose-biased vehicle. Even on a bad track, I still get in the low 1.7s when other 2wd guys running slicks are lucky to be in the 1.8s. I think they help because they change the instant center.Just fyi guys, traction bars do not actually aid in traction.
Shoulda put that in there, for some reason I always assume everyone already knows lol Mostly DD and ripping down the streets when I'm in a hurry and some towing
Turn off the Caps bro
