Bringing this back up (thanks for the reminder Trent! :rofl to ask a question.
I plan on removing the overload springs today. (I found correct bolts) Any opinions on how this will affect the Caltrac adjustments?
how the hell do you guys adjust them while they're in the top hole? the hex end is pointing forward and there is no way i can get a wrench on it...
I had the hex end on the axle side , not the front .......... the non nut hex end you should be able to adjust/twist the bar by hand , no need to crank past what your hand can do 1/4 to full turn preload is more than most run .
here is how mine was setup . not the best pic but .......yea i tried to run the nut in the back back the back heim wouldn't thread in... and my instructions said hex in the front so i figured they made it to only go one way.
Trent, you were saying a while ago that with your program you thought using a lowering hangar for the springs instead of lowering shackles might be beneficial. is this the case while using Caltracs as well? or would it only work better if they are clamped with no bars?
same problem
so I wenith Pro Comp MX6056 shocks, we'll see how they work. they have "hard" valving...dunno how hard it will be compared to other setups people have tried but its worth the $170 attempt i think.
Excellent thread with great info here guys.
I disagree with the statement that a suspension that squats will always "Pull" up the rear axle. It depends on the setup. Weight transfer will also cause the rear to squat, and it is inevitable that you will have weight transfer when you are trying to take a truck to 60' in 1.5.
I was watching "Passtime" a while ago and it was a special edition with a bunch of Vipers. Seems most of them had very little squat, and the tires were more inclined to break traction when there was less squat. I realize that we have the advantage of 4wd, but I still think there may be a lesson there.
Squat from the suspension will always pull the rear axle up. It is simple physics. If the suspension is attached to the rear axle, and the force of the rear axle makes the suspension pull the chassis down, the force of the chassis being pulled down must make the suspension also pull the rear axle up. It's one of Newton's laws; I don't remember which one though.Excellent thread with great info here guys.
How about Newtons third law of motion.
As far as your observation on the cars that didn't have any squat not breaking the tires loose, that could be any number of reasons. Too much anti-squat can also make the tires break loose, but it is usually after the car has launched off the line and already traveled a few feet. When a car hits the tires and loads the suspension it forces the axle into the ground, but it needs enough power and correct setup to keep the weight transferred and the tires planted. If you have it set up too aggressively, you will plant on the launch, but as the suspension settles in the tires will unload. There is a lot of reading out there on chassis setup if you search for it. Some of it can be quite confusing, but a lot of it is really cool stuff.
