buying used rods??
6,082
what is the reason he's selling the rods? i cant seem to come up with a reason someone would switch rods if the ones being used are perfectly fine...
He's going with a stroker crank
Nicks got it. I call and talked with Wade this mornin. He had a total of 6 passes on the rods, had all the rods fully checked out before selling, and told me he even planed to reuse his bearing that came out of the rods for the new ones. He is going with a fully interally balanced stroker crank in the new motor for a new pull season. Now granted this is his word but im willing to take the risk for the price i got.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I can attest to the durability of Crowers. I've run them at high HP, then removed them and remeasured them, and they stay stable. I stuck one through a block and it barely deformed. However, I've read internet rumors that there have been failures.
Rods are no different than any reused part you put into an engine. You should check the components before assy.
The minimum checks you could do at home:
Put a new wristpin in the small end. Should move free, and you shouldn't feel any rock (tilt).
Torque the rod (with bearing) onto a crank journal. Use assy lube. It can be a little tight at first, then it should get loose by working it in. Pull off cap. Put a piece of plasti-gage on the bottom of the cap and retighten (don't rotate), then pull cap off and check plasti-gage.
Assemble rotating assy and check piston protrusion. My Crowers are 0.004" longer than stock, but I also cut 0.010" off the tops of my pistons.
If everything checks out, you should be good. You should do this even with new parts as insurance.
I mentioned Wade Moody simply because he has sold "hurt" used parts here before.
6,082
thank you very much for the information Pat. it will be used :hug:
MD-Dmax
Jan 6, 2010
318
I am running a used set of crowers in my motor, haven't got to drive it much because of the oil pressure issue we had but I had them checked and they were fine. They came out of ed's (eds04max) truck, and I got a good deal for them
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
im running his cam and pistons. all is well with them. think ive but about 5k on the build
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Not that we aren't busy at work, but I have measuring laboratory with CMM equipment. I would charge $128 (+ shipping) to check: eye-to-eye, big and small dia, big and small roundness, tilt and twist on a set of 8 rods. To have this done, you need to clean the rods (just WD40 and a rag is fine), and torque the cap (no rod bearings) to the mfr spec, protect well, and ship to us. If somebody runs into a situation where they need accurate readings, PM me.
This is overkill for most apps, but just thought I'd throw it out there just in case.
Partial sidebar, we also do reverse engineering on parts. ie - If you have a part you need a blueprint for, we can create 2D blueprints or 3D models. Again, just informational, since not everyone knows there are labs such as ours that specialize in measuring stuff.
MD-Dmax
Jan 6, 2010
318
I wish I could put some miles on my build before this kit from Trent gets here but it looks like the motor won't get any break in miles before it does
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
Wish I had known that before I sent off one of my LB7 injector cups elsewhere.
Thanks for the FYI.:thumb:
6,082
this is good to know. if i feel these rods warrent closer inspection, ill be callin ya pat :D
I swear MD, you buy and sell more dmax stuff than a pimp in Miami on the day viagra was released to the public :D
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
I would never run a used rod:D You shouldn't buy these:hello:
j/k Im sure they are fine and wouldn't blink a eye about runnin them:thumb:
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
So he must be running a stroker motor now, cause hes been pulling all year, unless its another motor or something?
6,082
Haha good try buddy :D. They should be in the mail and at my door by the end of the week.
13,752
822
Looks like they have arrived. When are you tearing into it?
