So just put. Danville pinned water pump in the truck be made one or two passes on tune three and then this happened!? Now the pin is somewhere in the motor. Has anyone else had this happen?
LOL I GARRENNTEE that pin isn't in the oil pan...Some guys should keep quiet on here.
Not him he is always so sure of everything :hug:
It's just my luck. Only thing is I called Danville yesterday and they told me warranty is only 6 months for a $190 water pump. If that's the case I would probably be better off getting a oreillys pump for $50 with lifetime warranty and just pin it myself. (I can return a pinned pump if it's worn or broke to oreillys, have connections up there.)
I'm guessing you have a lbz since your sig says your cracked a piston awhile back? If so what was wrong with your factory water pump which made you install this Danville pump?
