LB7: Built tranny
aashton1206
172
Going back to the builder, truck has thrown 741 twice now
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
1,944
Moved to Transmission area. Cmon Ashton, help me out here.
Sean, you're crazy. :rofl:
aashton1206
172
Sorry man, make me an admin
aashton1206
172
No heat issues which is the tcc indicator, as well as solenoid f. All checked out. I'm thinking it's in the tune. I emailed nick to get me a tranny tune and see where that gets me.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Lol. Yeah a transmission tune will fix it right up.....
15,681
741 means the converter clutch never applied. Pink slippers tune will not help as he doesn't know how an Allison works. Put a Tech2 on it and see.
aashton1206
172
Already did, as I said two posts ago, the transmission checked out.
aashton1206
172
It runs like nothing is wrong with it but the code popped on. Hasn't come back since yesterday morning. I'm gonna head out to my builders shop tonight if I get out of work early enough and see if anything shows up on his hardware.
aashton1206
172
Iowa lly I meant the ecm tune cause it has never done it on my optimized stock or tow tune. Just my street and race tunes...
aashton1206
172
How do I check the tcc slip with my v2?
Also I pulled the filter last night and checked the dipstick and everything looks brand new, which it should considering it's week old mind you.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Take it back to the builder. Based on your signature there is no reason for you to be having TCC apply issues.
aashton1206
172
I am, I'm gonna log it tonight on the way there to see if there is actually any slip while in full lockup.
