Why does the crank break in the front?
Random thought:
If you do the trig, the bending force imparted on a crank by an externally balanced engine weight gets larger the smaller the dia of the counterweight is, and how close it is to the main journals. Our rear weight is on a large dia and close to the main, and the front is on a really small dia far from the main.
The answer might be as simple as a new design front weight, that moves the mass as close to main journal, and as far out radially as is possible. This could perhaps even be done to a factory harmonic balancer.
Random thought:
