Built motor Lmm help please
Dallas S
486
33
Alberta
Did crank break where the cracked piston is? I don't have any solid data but I won't run a crank that has had a cracked piston. Twice now I've had the crank break shortly after. First wasn't mag'd, second was.
I don't believe the massive imbalance helps these cranks. Should note both my cases, cyl 1 was the cracked piston so that probly didn't help any either
02bigstrokin
Sep 9, 2008
882
I'm not sure I haven't gotten it taken down but I would venture to say no. Number 8 had the cracked piston. It's broke up front. I reused my crank in my lb7 after melting/cracking a piston on my second 10 sec run. Never had a problem with the crank.
Thunderwood
Apr 5, 2014
66
Warrensburg, MO / North AR
Not sure I'd reuse the block. There is a salvage yard up in Ohio packed full of Duramax trucks. I was like a kid in a candy store.
Do you know the name of this heaven on earth you speak of?
Segan Underwood
2006 GMC CCSB LBZ
Built trans
DP 72vgt
100% II injectors
10mm stroker cp3
ARP head studs
PRO-FAB manifolds, up-pipes,Y-bridge, and boost tubes.
SDP 3" downpipe
5 inch MBRP exhaust
Traction Bars
PPE guages
EFI LIVE by Mark Broviak @ DP
