LBZ: Built LBZ daily driver issues
diesel53
Sep 16, 2010
907
AZ
Sooo I bought a built LBZ thinking I could daily drive it, but with the current tuning and turbo thats not feasible so I need some input.
Truck has:
s475 87mm turbine .90A/R
100% exergys
dual cp3's
So Without making tons of changes I was thinking getting a quick spooling s400 frame like a s363-4-6 with a smaller turbine so its not laggy and clean up the tuning. I dont think I can reduce laggy smoke with tuning only but maybe someone can let me know.
Plus I wanted to lift the truck and s475 with bigger tires is not smart haha.
Any suggestions would be appreciated. And if any has a turbo that would work for me let me know!
Thanks in advance for the input!
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
If I were you I would go back to VGT. You could sell the S400 and install kit and cover most of the cost of swapping back to a Danville 68r.
quinton
1,883
Granbury Tx.
Get a different converter... I have same turbo in lly with same injectors, I've ran a bigger a/r too and it wasn't too bad.
diesel53
Sep 16, 2010
907
AZ
I do like vgt turbos better, I just didnt know if that was cost effective.
I have the full HSP s400 kit with a s475 now. If I can do the swap for the price of that kit I would consider it.
Tuning cant clean it up? Im running danvilles tuning and well its dirttyyyy from what I can see. Runs great though haha
diesel53
Sep 16, 2010
907
AZ
Im not too concerned with losing hp, I just want 600-650 available to me. Not 800 plus.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
I've had people tell me I could spool a 472 with 30 overs and 1 pump. May not be fast but you should be able to spool and not haze everywhere. I'd try another tuner or have Danville retune it first.
diesel53
Sep 16, 2010
907
AZ
I agree, Ill try tuning first and see how it runs with less fueling.
torqued2dmax
646
Brookville, PA
Have you done a boost leak down yet ? My local builder Black Out told me that many hazing problems are from a cracked intercooler or boot that are easiest found by pressurizing sys .
quinton
1,883
Granbury Tx.
Exactly... could be the smallest boost leak somewhere and not able to here it from in the cab. That little bit makes a huge difference.... ask me how I know... lol
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
VGT turbo for your HP goals hands down. A s475 and 100% over injectors are miserable in a daily driver, no matter what converter or who tuned it.
Then it wasn't tuned right. I run 250 overs and a 80mm. Drives decent
* didn't think about elevation, runs good at sea level.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
You could always downsize the injectors. My truck runs pretty clean at <60% throttle with 45s. It'll black the road out though if it's not on the charger. A trans tune can also make a world of difference. Raising shift points to stay above 2k at all times and moving TCC lockup up around 65 really helps. My truck was a pig without a trans tune.
Slowmax
Build what others' won't
Aug 3, 2013
468
United States
Seen the same setup run very low clean smoke-less 10 second passes. I agree it's either in the tunning, or boost leak. Just ask Mark to pull fuel out of the tune, and go drive it.
