Built Gmax Failure
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,215
365
At Da Beach
Any casted housing is going to have weak points from air bubbles or foreign material in the mold. Every once in a blue moon the bad spot is where it causes the maximum damage when it gives. Sucks, but it's just the luck of the draw...
Burn Down
Sep 14, 2008
7,092
Boise Idaho
OK guys, if thats the way you feel when I am just asking for some input and possible information, I will not bother posting, thanks anyways.
Why are you getting all bent of shape? I just stated that's how I was reading it as well as Corbin... You cleared it up and said your just looking for input:thumb: It's the internet man, relax...
Pure Diesel
902
159
Ventura County
I did not read it as such. Sounds more like a "shit happens" scenario. Sorry to hear, cat.
Think about it: if cat didn't say where he had it built in his first post, the first reply back would've been some snarky remark like, "who built it" or "talk to your builder".
X2
catmenace
255
Just an FYI...Transmission is up and running again. Thanks to Mike L for pointing the builder up here in Canada in the right direction. Thanks Mike!!!:thumb:
600+duramax
Jan 18, 2007
I know on my Rossler turbo 400 there is a piece that Rossler adds to help keep the snap ring in place. It's works as a back up. I would also think that a built trans vs a stock trans would put more pressure on the snap ring. I'm no trans builder just my guess?
catmenace
255
From what I understand from Mike L, it looks like a solenoid stuck open and produced uncontrollable pressure. Apparently there has been problems with these. Mile L would have to chime in to verify though.
Evan@InglewoodTrans
yerp
3,118
65
Western MA
You can drive around with 500 PSI + of pressure and not have an issue blowing the lugs out the case. Considering how rare it is for it to happen with how many built transmissions there are out there and the fact they will do it stock form also it seems to be a luck of the draw case imperfection issue instead of something caused by to much pressure.
catmenace
255
Could be what you say. I don't know other then what was told to me. I know there was an adjustment made in the valve body at Mike L's recommendation.
