Hello everyone, I hope someone can help me with my no start problem, I just finished installing the engine and trans after both of them have been built. So the codes I have are P0341 Camshaft Pos Sensor Circ Perf (bank1/1 Sensor) and a egr code I can't remember, I have swapped both cam and crank sensors from a running truck that is a lbz also, same codes, tried the ECM out of the running truck and did the vats and vin change, same codes, did a continuity test from the cam sensor plug tho the ECM and checked out good. Now I'm just lost the only other thing I can think if is the wheel that the cam reads off of, sorry for the short novel but any help would be appreciated
