Sometimes they're tuff. You have to line up 2 sets of spline and the pump lugs. Sometimes billet shafts are tite if you're using one.
What would make it so hard to get it to seat?
I noticed mine was harder to stop in 4 low when I installed the ML Precision converter. Not bad just had to press the brake slightly firmer and I am used to it now.
My ML definately has a good bit of bite to it in 4LOW, so much so I have to go to neutral before park when in 4 low because it torques the bURB enough that if I don't I get a NASTY ratcheting sound when it unloads the driveline and engages the parking pawl(it also throws a VSS code when it does this). It's manageable, but you will notice a difference.
Waiting on production now.
"comparatively", yes, its easier to get the converter seated all the way with the trans standing vertical. It would probably be really difficult for someone who has never done one before to get it seated all the way with the trans sitting horizontally...but after you get the practice of doing a couple dozen of them, its no harder to do it horizontally vs. vertically.
Ben
On the longevity thing, the only thing I have heard (from Mike) is that running REALLY high line pressure will cause the C2 steels to beat up the input drum. Dunno if that shortens the life of the trans, but it might require a new drum come rebuild time
So, I'm going to be using a stock DMax converter with my wimpy motor. How does it "creep" in low range compared to the ML? I'm going to have 4:1 low range as well.....
Tim built my current transmission in the spring of 09, its a gmax kit, it has lasted through 11 and 10 second passes, and 2 years of sled pulling, it will be seeing a 4th season. Ive went through quite a bit of converters last year though. Im not blaming suncoast one bit, im not sure any converter will last long with 1-2 minutes on the line trying to light the turbo. There was quite a few times the paint was boiled off the converter, they usually lasted longer than i thought they would. At the end of the year we got the stall time down, and they seem to be holding up great.
