.250 does seem to be alittle over kill but at least it won't bend.
Is using heim joints on both ends ok?
Yes. Just use right handed threads on one end and left handed on the other. Then there adjustable.
Building a set for my cclb and am planning on using johnny hints on one end and bushings on the other, any issues with this? Bars will be 2" with 0.25" wall.
Also for length should I try getting them flat (~95"long) or should I run parallel to the second part of the drive shaft (~80" long)?
Sent from my DROIDX using Tapatalk 2
^ you did a little more then I was planning on. I'm planning on doing two tabs of the bottom of the frame and two tabs of the bottom plate the u bolts go through. Be on a slight angle but shouldn't affect anything...
