Broviak built his so I guess I'll build mine too
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
The truck made 733/1331 2000 pulse tune. 26.5 k rail!!! 40 boost 60 drive 1400 degrees
It is a monster on the street. Time for some break in!!!:woott:
redws6rocket
406
Odessa, MO
Where did your oil leak end up coming from? I had a friend not thread a head stud all the way down and hold up the valve cover. I didn't know if that's what happened? Congrats on the numbers!
Harbin_22
3,858
7
Southern Indiana
Well, here's the update.....I pulled the motor back out to investigate the leak, found I had a bad valve cover that wouldn't seal. Mark and I put everything back together and I finally fired it up last night... NO LEAKS.....Its been a long 2 months. I have to put the front clip and the driveline back in it tonight, then I will drive it tomorrow and let Mark make some noise on the dyno. Shooting for over 800 hp!!!!!!
Bad Valve cover
smkndmax05
"Smoked Out"
Feb 17, 2011
479
Indiana
Well it got a work out over the weekend on the 3rd tune and it feels a lot stronger than the dyno noted!!! Ask SmokinHotLLYgirl about 55-60 4th gear rolling burnouts.:roflmao: I'm seeing 45 lbs of boost 70 lbs of drive... It's a blast to drive!!:woott:
matt78
Finally boosted launches
Sep 10, 2012
924
texas
45#, I hit 46 sat night, got to order a new boot on my hot pipe. Thanks for posting drive #
