2 days ago I was pulling up my driveway my lly with 190k miles with mods in my signature, and it went to downshift into first gear (i have a longer driveway) and when it shifted the whole truck shook hard and started knocking/ banging. pulled it inside and checked the balancer with a 36mm wrench to do the "crank test" and sure enough there was a lot of clunking/play going on after belt tension was removed. So onto building this motor;
Using stock bore block
Wagler Rods
Delipped pistons
Main studs
AF 3388 So cal Cam
Clevite H bearings everywhere
DTS oil pump
Recondition heads/valve seats
new pushrods
titanium retainers, hamilton springs
new oil cooler
ATi Damper
MA motor mounts
Used LB7/LLY Crank???
Any opinions will be appreciated!
Wagler Rods
Delipped pistons
Main studs
AF 3388 So cal Cam
DTS oil pump
new pushrods
new oil cooler
ATi Damper
MA motor mounts
