LBZ: Broke my crank
BHoward6.6
West Coast
Feb 9, 2011
274
Huntington Beach, CA
So I'm pulling my 5th wheeler, 55mph all gauges normal. Drive press is 1 to 1, oil temp is 210*, oil press is good. EGT's are 1000*, boost is around 10~15psi. OAT is about 60*.
Then I hear a very bad sound, the sound of a rod knock, of in the distance, then getting louder. So I turn the cruise of when I heard it, looking for a place to pull over. Roll into the throttle and BAM, the truck shakes but still running to get pulled over. Get towed back home.
Can you see it.
BHoward6.6
West Coast
Feb 9, 2011
274
It is on my LBZ.
A short list of mods
ARP Headstuds.
RDL's EGR Delete pipe.
  • S475 over a
  • GT4094AVNT.
  • Both with Blankets
  • 3" IC Tube.
    • MBRP XP Series 5 in. Exhaust.
    • RDL CastFlow Manifolds & PPE Up pipes.
    • Blankets on up-pipes.
    • Stage 5 by Mike L.
Truck still ran. I started it and un hooked the 5th wheel.
1chevy02
Jun 23, 2009
504
Must have typed at the same time:thumb: Thanks for the info. Best of luck:hug:
BHoward6.6
West Coast
Feb 9, 2011
274
HP was 600 at the the wheels. The truck has 175,000 miles, alot of those were towing heavy.
I don't know if I am going to part it out or repair and sell it as a running motor.
I bought cuminstrkmydmax's SoCal stage 2 motor.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Wow relitivly low horse for what it could run i guess cant believe it broke like that Just wierd.Good luck with the new motor
BLKLMM
<<< Slow Mamba
Jan 31, 2010
2,142
Oceanside
:eek:
That was quick:thumb: nice:D
BHoward6.6
West Coast
Feb 9, 2011
274
All of the bearings (Rod and mains) were in great shape, except #4 main, the bottom was wore down just to the copper, the top was wore a little less, but stll toast. I looked for any blueing around were the crank broke and the #4 main bearings and saw none.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Probably sell it like it is ? Wish it was within reach for me to pick up.
