LLY: breaking up at 4k
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I have LLY's and LB7's with 250% injectors that regularly turn 5000+ rpms
Yes tony, but at what pulsewidth....
pat is saying that, regardless of injector size, a duration longer than 3000us, with the crank spinning at 4,000rpm, you'll get overlap.
I know you're not going to tell us what secret magic pulse width you use, but I guarantee its not 3000us with 250% injectors.
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
The size of the injector is not the issue, the pulse width at RPM is...
Dan@PPE
Diesel Enthusiast
Aug 8, 2006
2,570
So Cal.
No i dont feel it has anything to do with time. The truck I posted in the video has less than 3500 miles on it.
High RPM and High pulse width (over 3000us) will cause this.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I asked because the OP hasnt had this issue forever...which is why it is most likely a crank signal issue like Ben said. But those of you who suggest it is pw and rpm related keep going. Maybe a new thread in the tuning section?
GMC_2002_Dmax
The Still Master
I always recommend to my customers when they are running too much PW for what is needed to increase injector size to keep PW low and timing lower.
It was a few years ago that I tuned the truck and it has just acted up which probably means after two years it's not tuning related and is most likely sensor related.
I don't have magic, anyone can log what I do.........it's just not that easy to duplicate with a log what is actually done in the tune......:rofl:.......those add on tables and multiplier tables and limit tables all have to be right.
:thumb:
