breaking point 2
Dirtymaxx03
3,109
So theres compounds on the lml? Wonder how big or the flow of the fords turbo in comparison?
Good question although it doesnt really matter. The idea is to blow up the motor, not see which truck takes less mods to make the most power.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
In all honestly, I don't really understand why H&S is doing this. Kory is a better example on how far we can push a LML IMHO. Anyone can throw a bunch of nitrous on a stock motor and have it live for a dyno pull or 2. I just don't understand why their purposely trying to break the engine is all. More of a publicity stunt than anything. "hey we were the first" kinda thing, like they pulled with the LML 2 years ago with tuning, and the first to get bent over by the EPA :spit:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I say back the HP with a 1/4 mile run, Ford vs Denali..
Oh, yeah, the ford would loose with more HP and the "my truck is heavier" excuse comes out :D
JDub
607
Hooper, Utah
The Ford has a single S300 frame turbo on it, about 1150cfm. This LML is running compounds, atmo is around 1700cfm. Ford made like 620 on fuel with 40" M/T's on it.
I'm guessing the LML makes a strong fuel only number but gives up before it beats the Fords 884 number
Dirtymaxx03
3,109
X2. I'll bet it lays down a real good fuel only number, but as soon as the NOS comes out it will die.
sickdiesel
Apr 22, 2010
1,019
I disagree. its the same both ways. to get publicity. Kory told me was expecting his to blow in texas cuz he was spraying it alot as well.
They are both doing things to push the industry further and get the LML name "out there"
FC5452
301
Eastern PA
^^^ that would explain to reason that both Mfg's have under rated the potential of the motor, and both will prove to be stout builds. the issues on both will be keeping the power to the ground not?
bluessmax
Tabasco Injected!
Nov 4, 2010
1,143
Lake Charles, la
Ya I sprayed a 100 shot on mine considering I was having a issue getting more than 32-34 lbs of boost. Fwiw when we got home we discovered I was 30% down on actual fuel volume out of one of the rails. Problem solved :).... Much stronger.
H&S is doing some cool thangs
