Break In Oil or just the regular
straightpiperoar
Jul 20, 2009
146
Just about ready to try and start a motor that has just been built....Does anyone use break in oil....to start with or does everyone just use regular 15-40.....thanks mike
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
I've been running rotella t 15w-40 since day one in mine. Thats even what the engine builder put in it when i had my motor built
straightpiperoar
Jul 20, 2009
146
thanks for the info....It looks like I will be using maybe royal purple break-in oil for the first few miles....
schulte
Jul 31, 2010
449
CT
But with amsoils extended drain intervals, you can run up to 2xoem or 22000 miles!
:roflmao:
Any 15-40 is fine, because after the first 5 mins of running, id change it again.
That's nothing; my grandfather used to run Amsoil for 3 BILLION miles, and when he did a compression test, his motor actually had 230psi MORE compression than factory!!!
