Brakes??
9,905
151
Napa. Nuff said.
Delco or death for this guy.
Fwiw I've installed "expensive" rotors from napa that were warped right out of the box. Have a set on my Ford right now that are FN junk.
1,990
There's something else wrong there, Adam.
I mean, I could see it if you were hosing down a hot rotor with cold fluid, but cleaning the coating off a brand new rotor out of the box???
Ive used cheap rotors on a junker to NAPA's best (what you listed) on my truck, and Ive never had an issue....ever.
Something about that just doesnt seem right.
644
Napa. Nuff said.
Got 150k+ on rear rotors and ~80k on the front rotors and I do t have a turbo brake for better part of the last 100k
9,905
151
If you used brake clean you'd probably get 200 000 lol.
Sent from my D5803 using Tapatalk
644
I mean, I could see it if you were hosing down a hot rotor with cold fluid, but cleaning the coating off a brand new rotor out of the box??? Cheap rotors on a junker to NAPA's best (what you listed) on my truck, and never an issue....ever. Something about that just doesnt seem right.
I clean everything but the rotor with brake clean. Been like that for several years now. Stopped having warped rotors after I stop spraying then with brake clean..
644
Got 220k front and 150k rear on OEM rotors. Rear both had radius cracks through inner surface.
Got 308k on the truck now with no major issues.
Rear got a set of pads about 25k ago
9,905
151
Only Adam could warp rotors with Brake Kleen lol.
