Brake rotors?
1,947
BTW, just to add some fact to this thread, The two trucks use very different front rotors...
Your 02 (01?):
Part Number: NB 48880000
Product Line: NAPA Brakes Rotors
Attributes: # of Bolt Holes : 8
Bolt Circle Diameter : 6.5"
Brake Rotor Diameter : 12.79"
Brake Rotor Discard Thickness : 1.43"
Brake Rotor Thickness New : 1.5"
Brake Rotor Type : Disc Brake Rotor Only
Center Hole Diameter : 4.65"
Height : 3.51"
Maximum Lateral Runout : .004"
Vented / Solid : Vented
Mounting Type : Type K - Rotor Only. Wheel Studs Are Pressed Into The Hub Only. The Rotor Is A Loose Fit On The Hub & Is Retained By Either Machine Screws Or The Wheel Nuts. See Diagram For More Information.
Your 94:
Part Number: NB 4886242
Brake Rotor Diameter : 12.5"
Brake Rotor Discard Thickness : 1.22"
Brake Rotor Thickness New : 1.29"
Center Hole Diameter : 5.41"
Height : 2.76"
Mounting Type : Type L - Rotor Only. The Rotor Is Mounted Inboard Of The Hub. The Hub & Rotor Sections Are Bolted Together. Replace The Complete Assembly If Hub Flange Is Bent Or Damaged. See Diagram For More Information.
Different mounting types, much different dimensions. Swap wont work no matter how you try.
Just deal with the pulsing brakes while you save the $90 for the proper front rotors.
